Error usingEXE/Building Installer, and cFP .iak error
I built my app and created an .EXE, however when I run it, I get the error(see image error1.jpg) "Cannot Load the browse dialog. Some necsessary components are missing.to correct the problem, reinstall the driver software that is associated with this control." when I try to bring up the Filedpoint browse dialog. This when ra on the computer with LV8.5 full devel. version. If I just run the VI, everything works fine.
Also, when I try to build an installer, I get these errors: (see image)
And then the final question, whenever I shut down labview, I have to open MAX, create a new .iak file, "find devices" for each FP-device and then press "start" so I can see the current values. Then I have to remove the FPdevices from my project, and readd them (new targets and devices), (importing the Fieldpoint configuration does not work). then it all works again untill I close labview. might it be associated with the fact that I cannot save the config file in the project? (see image) when I close the window again, the configpath is gone and when I clock add it says "warning, error saving file".
thanx.
Anders
Message Edited by Tohatsu on 02-13-2008 04:07 AM
Message 1 of 8
(4,317 Views)
I am having the same problem with the building an executable.  I haven't come up with a solution yet.
Director of Engineering
G Systems, www.gsystems.com
Certified LabVIEW Architect
Certified LabVIEW Embedded Systems Developer
GCentral
Message 2 of 8
(4,301 Views)
related to not beeing local admin?
And plese not "might be, try it" because it's a complicated procedure here and a potential security hazard, so I'd gladly avoid it if possible.
Anyone?
Message 3 of 8
(4,282 Views)
bump
Ideas? Suggestions? anyone even reading this?
-Anders
Message 4 of 8
(4,225 Views)
Yes, someone 🙂
I have this same problem, even stranger:
I created exe, that use Browse dialog for FieldPoint adresses.
I run exe at this same computer, with this same *.iak file and "Cannot load..." like at yours.
Strange becouse I've made that exe at this computer and my source in project (VI) can browse cFieldPoint tags.
Regards
Mikrobi (Zbigniew St. Sobków)____________________________________________________________
"You can lead a horse to water, but if you can get him to float on his back you've got something."
Message 5 of 8
(4,213 Views)
I've just found temporary (let's say) solutions:
About my exe:
test editor for cFP, so I have to allow user to set cFP chanel (let's say DO1), set description, and create table of boolean values.
I want to use cFP "Browse" dialog, but:
there is a VI called "FP get Configuration Info.vi" (Functions>>Measurements I/O>> FieldPoint>> Advanced>>cFP Get Configuration Info)
Set path to *.iak file, define configuration name, communication resource (MAX's cFP name) and device name (l.s: cFPAI-111@3) and operation  get item list (long string)
It will get us all input adreses at module cFP-AI-111 and next module and so on...
So user will operate at ring or listbox to select cFP channel what is, hmm... proper solution when he isn't connected to cFP at my exe. 😉
Regards
Message 6 of 8
(4,205 Views)
Are you local admin on your computer? cause I'm willing to try that if nothing else helps.
Not quite sure what you mean by your example, I dont have that "advanced" icon on my palette(see image below). Are you local admin?
There must be someone that has been able to build a working VI with the browser right? These were the exact reasons why we chose software and hardware from the same company, so there would be no compatibility issues...*sigh*
Message Edited by Tohatsu on 03-10-2008 07:39 AM
Message 7 of 8
(4,185 Views)
Yes, I'm locala admin, but I suppouse it isn't important.
I sugest reinstalation or full instalation cFP drivers from NI ftp, at my computer cFP palette looks like that:
and simple realisation:
Regards
Message 8 of 8
(4,175 Views)
