02-13-2008 04:05 AM - edited 02-13-2008 04:07 AM
thanx.
Anders
02-13-2008 12:43 PM
02-18-2008 06:29 AM
03-07-2008 05:02 AM
03-08-2008 11:47 AM
03-08-2008 03:52 PM
I've just found temporary (let's say) solutions:
About my exe:
test editor for cFP, so I have to allow user to set cFP chanel (let's say DO1), set description, and create table of boolean values.
I want to use cFP "Browse" dialog, but:
there is a VI called "FP get Configuration Info.vi" (Functions>>Measurements I/O>> FieldPoint>> Advanced>>cFP Get Configuration Info)
Set path to *.iak file, define configuration name, communication resource (MAX's cFP name) and device name (l.s: cFPAI-111@3) and operation get item list (long string)
It will get us all input adreses at module cFP-AI-111 and next module and so on...
So user will operate at ring or listbox to select cFP channel what is, hmm... proper solution when he isn't connected to cFP at my exe. 😉
03-10-2008 07:38 AM - edited 03-10-2008 07:39 AM
Are you local admin on your computer? cause I'm willing to try that if nothing else helps.
Not quite sure what you mean by your example, I dont have that "advanced" icon on my palette(see image below). Are you local admin?
There must be someone that has been able to build a working VI with the browser right? These were the exact reasons why we chose software and hardware from the same company, so there would be no compatibility issues...*sigh*
03-10-2008 09:05 AM
Yes, I'm locala admin, but I suppouse it isn't important.
I sugest reinstalation or full instalation cFP drivers from NI ftp, at my computer cFP palette looks like that:
and simple realisation:
