Error ring excluded in executable?
Sure, if you share a reference (DVR), you have to make sure that no client destroys the reference while other clients are still using it. But this should not be an argument against sharing a reference, shouldn't it? For example, you can "hide" the reference in methods of objects and use access rights to control which client can do what (read, write, destroy, etc.).
In our project we implemented a shared memory which is a LabVIEW object and all clients own a DVR pointing to the object. Reads and writes of the shared memory are done via IPEs.
Message 21 of 25
(1,670 Views)
A class DVR is the basis of G# to make it reference based and all data modification functions uses the IPS to modify data since it also encompasses a semaphor function. We have had no issues so far in that regard.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 22 of 25
(1,592 Views)
Hi Peter,
I have filed CAR 522606 for this Error Ring issue. Thanks for reporting it and for the nice example.
Best Regards,
Nathan Burke
Product Support Engineer | LabVIEW R&D | National Instruments | Certified LabVIEW Architect
Message 23 of 25
(1,546 Views)
Smiley Frustrated  I might have come to the party late, but I think it is clear that this is a compiler optomization problem, not an error ring issue.  I hope whoever looks into this reads this thread and realizes that.
Message 24 of 25
(1,529 Views)
CAR 522606 was fixed in LabVIEW 2017.
Message 25 of 25
(1,128 Views)
