How to load/import/extract Axon Instrument .abf file 2.0.4 version?
Hi all,
We recently set up a low current measuring system using Axon Instrument's devices, and the data recorded are in .abf format 2.0.4 version. I know there's an example VI about abf file format here: http://www.ni.com/example/30979/en/, but it only supports up to 2.0 version. Is there any support for loading/importing/analysing .abf version 2.0.4 file format?
Thank you!
Weisi
(3,727 Views)
Have you tried the example VI to see if it works? I wouldn't expect a version number 3 places out to make too much of a difference.
Are the differences documented anywhere?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,713 Views)
Actually I have and couldn't load it. That's why I'm seeking help here. Not only LabView, most of the softwares that support abf 2.0 don't support 2.0.4. I wanted to attach an example file here but I think this format isn't allowed to be upload...
I'm actually writing to the salesman at Axon Instrument for some documentation on the new version 2.0.4.
(3,689 Views)
Here I attach a sample data file if you can help me?
Thank you so very much!
(3,660 Views)
We are having the same problem for a new setup we recently ordered. It seems that the new digititzer is causing the problem.
Have you got the problem solved? If so, may I ask how it is solved since it is giving us a hard time for now.
(3,262 Views)
