Error only on using xalan:evaluate - error Could not compile stylesheet
XSL does not compile when and only I use xalan:evaluate.
Setting in system properties
sysProps.setProperty("javax.xml.transform.TransformerFactory", "org.apache.xalan.xsltc.trax.SmartTransformerFactoryImpl");
XSLT snippet
<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:xalan="http://xml.apache.org/xalan" exclude-result-prefixes="xalan">
<xsl:template name="my_test_template">
<xsl:param name="my_test_param" />
<xsl:if test="xalan:evaluate($my_test_param)">
some statements
</xsl:if>
<xsl:if test="not(xalan:evaluate($my_test_param))">
some statements
</xsl:if>
</xsl:template>
ERROR LOG
ERROR: 'Cannot find external method 'org.apache.xalan.lib.Extensions.evaluate' (must be public).'
2015-04-14 08:19:52,509 XslTransform ERROR> Error creating 16 template, will skip compile and use interpretive mode instead
javax.xml.transform.TransformerConfigurationException: Could not compile stylesheet
at org.apache.xalan.xsltc.trax.TransformerFactoryImpl.newTemplates(TransformerFactoryImpl.java:832)
at org.apache.xalan.xsltc.trax.SmartTransformerFactoryImpl.newTemplates(SmartTransformerFactoryImpl.java:319)
(2,948 Views)
How is this a LabVIEW problem?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,918 Views)
