Connect the temperature and humidity to turn on the fan
Guys! I need some help on my connection how to connect the circuit?
The first one I want to connect is my Thermistor Data. Then I want to connect the Temperature Control to turn on the fan. How to do?
Aloysius Low, Student
Message 1 of 16
(4,647 Views)
Accepted by topic author aloislowintown
For homework help, ask your fellow students or your instructor.
BS
Message 2 of 16
(4,639 Views)
But the fact I really not sure how to connect, sorry, and I just need some help how to get the temperature icon, can you help me?
Message 3 of 16
(4,630 Views)
Stop posting huge photographs! They accomplish nothing. There are examples that show how to do analog input. Start with them and if you get lost ask specific questions.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 4 of 16
(4,612 Views)
The fact that I just want the solution where to get all those things in my LabView.
Message 5 of 16
(4,607 Views)
Dear NI Team,
Basically How do I get the temperature icon in the LabView? And my the myDAQ device can't connect to my PC. If not pop-up the device, so what should I do?
Cheers
Aloysius
Message 6 of 16
(4,574 Views)
Hi!
Can you help me how to get this icon? And show me how you do. Thanks.
Cheers
Aloysius
Message 7 of 16
(4,561 Views)
@aloislowintown wrote:
Hi!
Cheers
Aloysius
It is clear that you have no idea even about the basics. Why a teacher would throw a task to a student, who does not know practically anything about LabVIEW? Did you not miss some lessons?
Either way, you should try to learn some before you try to program in LabVIEW.
Here is a link:
http://forums.ni.com/t5/LabVIEW/Idiom-for-initialising-a-sub-VI/m-p/3086564/highlight/true#M882347
Regarding to your actual question: as I see you want to create a subVI (what you call an "icon") which converts thermistor resistance (?) into temperature. The subVI which you posted, has one problem (i did not check the calc itself though) with the numeric output, it should be an indicator, not a control (right click and change to indicator). I do not understand your question about "How to get this icon?". You have attached this subVI to this post, so you have it. You are asking how to put this subVI into another VI?
Message 8 of 16
(4,541 Views)
Anyway I got the tutorial book, so basically I will read to touch up more on LabView. Thanks
Message 9 of 16
(4,527 Views)
Hello... When I get a temperature reading, when I set Minimum Temp is 0, and the Maximum Temp is 38, and I key in 37 or below in the current temp then it indicates as Heatstroke Warning.
Message 10 of 16
(4,463 Views)
