Error message
from the VI "New Report" I'm getting the error message "Klasse nicht
registriert" (i.e. in English "unregistered class" or "class not
registered").
Can someone please tell me what this means and advise some remedy?
Thank you
Klaus Hoelscher
(3,292 Views)
Hi Klaus,
try this:
- Locate in your PC NIReports.dll
- Execute the following command:
regsvr32 "complete path of NIReports.dll"
Example:
regsvr32 "c:\programs\national instruments\labview 6\shared\NI-reports\nireports.dll"
- Do a mass compile of all Reports vis
This registers the nireports.dll in your system. I had this problem when I updated form LV 6 to LV 6.0.1
Good luck,
Alberto
(3,292 Views)
this worked fine for me with Windows NT4.
Now I try to do exactly the same command under Win 2000. This ends in the following error message:
DllRegisterServer in "C:\USERDATA\Programme_DEV\LVRT\NiReports.dll" failed. The error code was: 0x80020009
Any Ideas?
Heiko
(3,292 Views)
