Error message in application builder in Build Application.vi
I'm trying to make an executable file but I recive the following error message:
Error 1003 occurred at Open VI Reference in Dist Copy Non-VI Files.vi->Dist Build LLB Image.vi->Dist Build App Image.vi->Build Application.vi
Possible reason(s):
LabVIEW:  The VI is not executable.
Does anyboy know the reason for this message?
Thanks.
Javier de Pablos
(3,125 Views)
Can you pls try the things that are said in this KB and let us know if u ar in any of those situations?
http://digital.ni.com/public.nsf/websearch/705C2ECA081F3C7986256C0F00559B02?OpenDocument
Jaime Cabrera
NI Applications Engineering Spain
(3,108 Views)
Hello Jaime,
I've tried to compile a very simple VI (there is only a while loop that executes nothing and counter is wired to an indicator.
I've attached you.) and I've got the same error.  So the code or any dynamic VIs are not the problem.
I've repaired the Application Builder within Control Panel > Add and Remove programs but I haven't resolved the problem.
Javier de Pablos
(3,095 Views)
Can u check this links to find a possible solution?
http://forums.ni.com/ni/board/message?board.id=110&message.id=3817&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=170&message.id=178723&requireLogin=False
Try also:
force recompile his program, look for VIs with identical names, and copy the block diagram to a blank VI
Let me know if that works...
Jaime Cabrera
(3,091 Views)
Something was wrong in LabVIEW but I don't know what.  I've installed again LabVIEW in the computer and now I can create executable files without any problems.
Javier de Pablos
(3,075 Views)
Ok...
good to know u solved the problem... It is always better to try almost everything before doing reinstallation or something like that, but nice u have everything working now!
Jaime Cabrera
(3,072 Views)
