Error in opening labview project
Hi ,
I am trying to open a Labview project. it is throwing an error saying "a project could not be created because one or more required components could not be found".
Any suggestion for this.
Attached snapshot.
Message 1 of 8
(3,732 Views)
That's not much to go on.
You need to make sure all required components can be found...
I've not seen this error before. But without more information (maybe the project, zipped) it would be impossible to guess what's going on.
Message 2 of 8
(3,704 Views)
The Labview vi.lib and other files in "C:\Program Files (x86)\National Instruments\LabVIEW 2017" are modified and few files deleted in my system.
This is because ,I tried to create a deployment file in Teststand using Teststand deployment utility. The Teststand utility modified all the files of Labview folders. Not sure why deployment utility modifying  these folders. Any idea?
Anand
Message 3 of 8
(3,702 Views)
That seems relevant. Hope you have SCC?
Can't help you with TS stuff though. But trying to undo what it was TS did seems the way to go.
Message 4 of 8
(3,696 Views)
I am trying to uninstall and install Labview again.
Anyway what is SCC?
Anand
Message 5 of 8
(3,693 Views)
SCC - Source Code Control (wiki) (e.g. SVN, HG, GIT).
It's one of the most essential software tools that you don't know you've been missing until right after you start using it. Check it out, and seriously consider using it. It will change your programming experience for the rest of your programming life.
EDIT: this might a better read. Or this, or this. Anyway google goes a long way.
Message 6 of 8
(3,689 Views)
Thanks, Got it, another example is clearcase.
Message 7 of 8
(3,686 Views)
A horrible and terrifying example, but yes. 🙂 (I really didn't like working in it)
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 8
(3,682 Views)
