Error in compiling LabVIEW FPGA target
Hi I get the attached error when I build my LabVIEW project.
I use Xlinx 14.7 to complie the code and the code is developed in LAbVIEW 2013 fp2
I also use NI DlexRIO 14, NI-RIO 14.0.1
(4,099 Views)
Hi tintin_99,
are you sure you can connect to Invensense compile server? What is an Error code written in Details option? Can you compile it on local compile server?
CaravagGIO
(4,063 Views)
It doesn't allow me to select local server because I can't see the server oprtion window when I click on build
Can I use Xlinx 14 tools with labVIEW and FPGA module 2013  or is it for labVIEW 2014?
(4,039 Views)
You can use Xilinx 14 with LV2013. The option should be in Tools > Options... > FPGA Module > Compile Server.
(4,034 Views)
I changed the server to local from Tools\Options\FPGA Module
But still when I compile it I get this error message. I still can't compile it because it asks for Xilinx 14.4
I have also downloaded 14.4 but I can't insall it because as soon as I try to insatll I get teh attached error
(4,033 Views)
You can try to use NI Update Service to install Xilinx tools and check if your OS is compatible with Xilinx tools
https://www.ni.com/en/support/documentation/supplemental/18/labview-32-bit-vs--64-bit-applications-f...
(there are links for different OS at the bottom of the page).
(4,003 Views)
Hi tintin_99,
Did you manage to solve the problem with what CaravagGIO suggested?
Kind regards,
SFuller
(3,940 Views)
