Error in REST API
Error code : 2
lib_NI_Advanced HTTP Client.lvlib:Session.lvclass:Open Session.vi:7490001<APPEND>
<b>Complete call chain:</b>
REST Client.lvlib:REST Client.lvclass:New Client Handle.vi
REST Client.lvlib:REST Client.lvclass:Create REST Client.vi
Main Screen Modbus multi - test.vi
Getting above when accessing the REST API , current i am using LabView 2025 Q3 version  32 -bit ,
can provide solution ASAP
(509 Views)
From here:
https://forums.ni.com/t5/LabVIEW/NI-Advanced-HTTP-Client-Cant-use-DLL-in-Executable/td-p/4468207/pag...
"the workaround for this issue is to install any run-time engine on the machine that is version 2024 Q3 or earlier. That should make the Advanced HTTP VIs work again in LabVIEW 2025 Q1 and later."
(468 Views)
Hi NI-MAX Acquisition, has Kyle97330's reply fixed your issue? If so, please don't forget to add a kudos to his reply and accept it as a solution.
(405 Views)
