Error in Bildung exe
I want to build a Application.
But when I start to build, after a while the following message appears:
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 8 occurred at Invoke Node in AB_EXE.lvclass:Build.vi->AB_Build.lvclass:Build_from_Wizard.vi->AB_UI_FRAMEWORK.vi->AB_Item_OnDoProperties.vi->AB_Item_OnDoProperties.vi.ProxyCaller
Possible reason(s):
LabVIEW:  File permission error. You do not have the correct permissions for the file.
Method Name: Build:Application
(2,776 Views)
Hi ruedi,
can you run your program without errors in development mode? Do all vi's have the blockdiagram?
Mike
(2,774 Views)
Accepted by topic author ruedi
Hello MikeS81,
the problem was somewhere between my ears.
The Programm is stored on a network- drive and one of my colleages was running it while I was building the EXE.
So the Application builder was not able to override the exe- file.
Thanks for Your quick answer.
Ruedi
(2,762 Views)
