Error in Actorframework in LabView 2025
I try to work with the Actor framework undser LabView 2025, there is aq Error in Software when creating a Message here are two Screenshots
it happens on two different Computers, it worked with LabView 2022, LabVIew should be right installed
(139 Views)
Did you try a English LV install or a 64 bit one?
I think an issue as yours would be known but German 32 bit is maybe little used.
Actor Framework
(118 Views)
Error 7 is "File not found". Does it exist?
Qestit Systems
Certified-LabVIEW-Developer
(47 Views)
