Error has occurred when listing the contents of xxx.llb
Help! I get the above error when opening a VI Library. Is there any way at all to recover the contents or some of the contents?
Message 1 of 11
(4,896 Views)
You should ask NI Support if they are able to repair your LLB. From the heading I could see that this should be a LLB created from a LV on a Windows system (if I interpret the first few bytes right).
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
Message 2 of 11
(4,893 Views)
Hello Aljrob,
Thank you for contacting National Instruments.
I was able to uncorrupt 10 VIs from your LLB file. I hope this is everything you needed.
Let me know if there is anything else I can help with.
Sean C.
Message 3 of 11
(4,893 Views)
Wonderful, thank you so much for your help!
Alastair.
Message 4 of 11
(4,893 Views)
I have a similar problem to the one described above, and I contacted an NI engineer, and he applied a .llb decorruptor vi and it did no good (we tried the other file referenced in a message above, and it worked fine for that).  Can anyone help?
Message 5 of 11
(4,732 Views)
Good news!  It turns out that I got all my files just fine as I had backed them up, so I don't need anyone to pick the file apart from my last message.
Kevin
Message 6 of 11
(4,726 Views)
Good, as it's not very likely that some other than NI could recover your VIs. I'd also like to mention that I don't think it's a very good idea to store development VIs in an llb. A single bad VI can corrupt your entire file.
Message 7 of 11
(4,724 Views)
I too believe I am having a similar .vi or .llb corruption issue.  I can not however attach my code in a public forum to try and have it uncorrupted.  Is there an e-mail that I can use to send my .llb to NI to see if the file can be recovered?
Message 8 of 11
(4,535 Views)
Hi mulud,
If you currently have a support contract through National Instruments you can request support here.
Cheers.
Michael K. | Applications Engineering | National Instruments
| Michael K | Project Manager | LabVIEW R&D | National Instruments |
Message 9 of 11
(4,517 Views)
I have same problem.
Could everyone to help me decorrupt  my LLB?
Message 10 of 11
(4,379 Views)
