Error exporting MAX Task to file
Hello I would like to export NI Task to file. However, I am getting this error
Error -2147220444 occurred at nisyscfg.lvlib:Import.vi:
Under the Possible errors, i get this message:
Possible reason(s):
NI System Configuration: (Hex 0x80040424) The operation failed because of unresolved conflicts
Did anyone have this problem before, if so, can they share their experience?
Now on LabVIEW 10.0 on Win7
(2,878 Views)
Accepted by LV_Enthu
Hello, Take a look at the KnowledgeBase article below. I think that the root of the problem your encountering is that the functions you are using are available only in LabVIEW 8.5 and later. Could you try to export the task in MAX itself? Otherwise would it be possible to upgrade LabVIEW? You may have to do that or go thorugh a potentially very difficult process of installing an earlier version of MAX.
http://digital.ni.com/public.nsf/allkb/BBB5B94C038267DF8625723E00030559
Alex D
Systems Engineer
Academic Research
(2,831 Views)
