Error during installation of patches and critical updates
My NI Update Service just provided 7 critical updates and patches, which I downloaded and tried to install. However, two installations were unsuccessful andproduced the attached error messages. A possible reason for the errors may have been that the laptop went to sleep during the installation, but I am not sure about that.
My question is how, I can find and try to re-install those critical updates and patches? The NI Update Service does not provide me with a list of installed updates and their status like the Windows Update does. Please advise. Thank you.
(3,779 Views)
Accepted by topic author pbuerki
Update Service saves the suite of installers in C:\ProgramData\National Instruments\Update Service\Installers\NI_date_time. You can try re-running the setup.exe.
If the error happens again, it must be a more general installer failure, but we can look more closely at the error code to debug from there.
LaRisa Mohr
Staff Product Support Engineer - NI Update Service
National Instruments R&D
(3,775 Views)
Hi LaRisa,
Thank you for your quick reply. I found the setup program in the location you described. This time, running the setup went flawlessly. Attached below is the installation summary. I am using LabVIEW 2011SP1 with the Device driver DVD that came with the LabVIEW 2012 Evaluation DVDs. Thismay explain the messages in the NI-DCPower 1.7.5 section. Thanks gain for your help.
Peter
Installation Summary
Installed
LabVIEW 2011 SP1 (32-bit) f2 Patch
LabVIEW 2011 FPGA Module f1 patch
LabVIEW 2012 Real-Time Module f1 Patch
NI-488.2 3.1
NI-DCPower 1.7.5
NI-RIO Patch for using sbRIO-9632/9642 with LabVIEW 2011 and 4.0
NI-Serial 3.9
Installation Details
No software installed or removed.
NI-488.2 3.1
Added or Changed
NI-VISA 5.2
Run Time Support
NI-DCPower 1.7.5
Could Not Install
Core Required Components
NI-DAQmx 9.1.7 (higher version already installed)
NI-VISA 5.0
Run Time Support (higher version already installed)
NI Measurement & Automation Explorer 5.0 (higher version already installed)
NI Spy 2.7.2 (higher version already installed)
NI System Configuration 5.0.0 (higher version already installed)
LabVIEW 2010 (64-bit) Support (incompatible with products already installed)
LabVIEW 2010 (32-bit) Support (incompatible with products already installed)
LabVIEW 2009 (64-bit) Support (incompatible with products already installed)
LabVIEW 2009 (32-bit) Support (incompatible with products already installed)
LabVIEW 8.6 Support (incompatible with products already installed)
LabVIEW 8.5 Support (incompatible with products already installed)
NI-Serial 3.9
Added or Changed
NI-VISA 5.2
Run Time Support
(3,761 Views)
