Error code 21
Hi
I am facing one problem while running the EXE that is copied from another system.
Existing system having labview 7.1 with NI scope 2.7. But the new system having labview6.1 and labview 7.1 run time engine with NI scope 2.6.
I have attached the Screen shot of that error.
Please give me an solution..
(5,353 Views)
Accepted by topic author srii2sree
Hi Srii,
Next time you attach an image you should use a real image format (like PNG or JPG) instead of some curious Office file!
The error message is quite clear: there are missing routines.
The standard answer is: To avoid such errors you should create an installer for your executable and run the setup routine on that second computer to install all needed software parts…
(5,329 Views)
Thanks for the reply..
Now i am not having that code to build the installer...
Instead of that whether it is sufficient to install that necessary Scope and DMM driver in the new station?
Please provide me another way without creating installer.
(5,294 Views)
You need to figure out what drivers and toolkits are needed for your executable and install them.
(5,244 Views)
My Problem got solved...
I installed missed NI Scope and NI DMM correct version...
Now the EXE is running fine
(4,960 Views)
