Error code: -200077
voltage converted to pwm (external device)
Message 21 of 27
(1,168 Views)
John,
I was curious about how the details of how voltage output mapped to the motor's response.
0V = off?
5V = X RPM?
Is the motor's response fairly linear over this range?
Are your relays actually changing the motor's power connections to make it turn in reverse?
I'm just trying to understand how your system works.  Like I said, I'm not well versed in PID but if I have some time this sounds like a good way to learn.
Dan
Message 22 of 27
(1,160 Views)
0V = off
5V = 6kHz
linear. Ya.
Anybody know how to define the sinusoid profile (forward for a meters distance and reverse for a meter distance) in the setpoint pid??
Message 23 of 27
(1,156 Views)
Would something like the attached VI work for you?
Dan
Message 24 of 27
(1,150 Views)
when I run the vi, heres the graph showing the result, see attached.
How to see its sinusoid forward and backward a meter each? Am I forgot to key in something? help to guide a little. thanks
Message 25 of 27
(1,142 Views)
John,
I forgot to save the vi with default values, but I think you'll need to set 'dt' to something non-zero.
Dan
Message 26 of 27
(1,132 Views)
thanks...cheers! you are one of the experts here!
Message 27 of 27
(1,127 Views)
