Error code: -200077
when i use PID to control the analog output voltage from DAQmx, theres error message saying
-200077occured at DAQmx Write (analog ID wfm N Chan N samp).vi2  requested value not a supported value for this property.
what does this error stands for?
Message 1 of 27
(5,886 Views)
You provide very little information, but I'm going to guess that you're trying to do hardware-timed analog output on a DAQ device that doesn't allow hardware-timed analog output.
What DAQ device are you using?
Message 2 of 27
(5,880 Views)
pci 6221
Message 3 of 27
(5,869 Views)
can help to explain what do you mean by " you're trying to do hardware-timed analog output on a DAQ device that doesn't allow hardware-timed analog output."
thanks
Message 4 of 27
(5,867 Views)
PCI-6221 will do hardware-timed analog output, so your problem is somewhere else.  Can you post your code?
Message 5 of 27
(5,864 Views)
DAQ assitant 2 is used to read the encoder angle (travel distant),
however, the other DAQ assitant is used to output analog voltage to convert to frequency output for motor.
setpoint profile is the intended distant travel.
 what do you think?
Message 6 of 27
(5,852 Views)
You still have not provided any code so you will just have to figure out the problem yourself. Do you really think that an image of the block diagram is going to show how you configured the DAQ Assistant?
Message 7 of 27
(5,845 Views)
John,
There should be some additional information that is returned with the error code.  Can you place indicators on the 'error out' terminal of your DAQ assistants, and look at the string in the 'source' member of the error cluster?  Typically the offending property is mentioned here.
Dan
Message 8 of 27
(5,839 Views)
dynamic data.png illustrates using DAQ assitsant to acquire encoder signal. And the data output from DAQ assistant is a dynamic data. This dynamic data will go into the pid process parameters.
However, if we see the DBL data.png. This vi using DAQmx read to read the encoder value, and the output is DBL data(in degree).
Why one is dynamic data, the ther one is DBL data?
Message 9 of 27
(5,833 Views)
Those pictures you posted aren't much use.  As Dennis pointed out, we cannot tell anything about how your DAQ assistant is configured by looking at a picture of a DAQ assistant.  Please post your code.
Message 10 of 27
(5,814 Views)
