Error caused by remote control?
I just got some great help here, and everything was working.  However, now when I run the code, I get Error Caused By Remote Command on my meter (Agilent 34461A).  However, when I run in the debug mode by  clicking the light bulb, this error doesn't happen.
The change I made was that I initialized the measurement outside of the while loop so that I didn't have to initiialize it for each iteration and I added a Read?
Any ideas why this would cause this error?
(7,307 Views)
_natalie_ wrote:  However, when I run in the debug mode by  clicking the light bulb, this error doesn't happen.
That points to a race condition with the instrument.  Try adding a wait right after your initialization.  Something like 10ms will likely fix it.
(7,302 Views)
I tried that, but it isn't working.  I put it in right after the measurement initialization.
It is also doing it in the debug mode.  It happends right after the Read?.
(7,280 Views)
Oh and I should add that the code keeps running and recording the current.
(7,278 Views)
And it only happens on the first iteration.
(7,267 Views)
Accepted by _natalie_
After reading through the manual some, I found that you actually want to use "CONFigure:CURRent:DC" for your setup command.  Apparently, the MEASure system causes a read to happen.
(7,257 Views)
Thanks again!
I would never have thought of that, but now I won't make that mistake twice 🙂
(7,252 Views)
