Error Reading Cluster from disk
im trying to create error cluster of wire type yellow color, i tried and im getting only pink color , could u help me
Message 1 of 15
(4,690 Views)
What function you are using to read from disk?
-Those are called Dbl(Yellow) and String(Pink) colors. try to read about data types in LabVIEW instead of using Color to refer them.
uday
Message 2 of 15
(4,678 Views)
i created cluster with three data types boolean,string, numeric , i need wire of type yellow color, here i attached screen copy for u
Message 3 of 15
(4,665 Views)
Instead of screen copy which doesn't give any info please post actual code(VI).
-Can you explain bit more on what you are trying to do?
uday
Message 4 of 15
(4,658 Views)
Hi kashizudoto,
you find ready-to-use error clusters in the "Array, Matrix & Cluster" frontpanel elements palette - you don't need to create them "manually"! (Or you create FP elements by right-clicking a connector pane and choosing Create->Control/Indicator!)
The error cluster is a cluster of boolean, number and string. In exactly that order!
Message 5 of 15
(4,654 Views)
im trying to code OFDM technology using 16 QAM modulation, i will send you the vi file kindly look at it.  i created an array for 16-QAM modulation with cdm data representation and used while loop. i need error in function as yellow color .
thank u
Message 6 of 15
(4,651 Views)
Hi kashizudoto,
Why do you need a special color?
This is a part of your VI block diagram as shown on my computer:
Why is the error cluster/wire not "dark yellow or brownish" for you as it is for me?
Message 7 of 15
(4,647 Views)
There appears to be a skill set mismatch here.  It's like you're asking us to help you rebuild an engine, but you're stuck on the color of a spark plug wire.
May I suggest going to the main forum page here and taking some of the tutorials in the links under Getting Started with LabVIEW?  At this point, I still don't understand your problem.  😞
Bill
CLD
(Mid-Level minion.)
Message 8 of 15
(4,638 Views)
1. Error Cluster Constant can be found in the palette.
2. You can quick drop it with Ctrl+Space, type "error".
3. R-click any other function with error in/out and r-click --> Create constant. You can even drop a function just to create the constant, then delete the function.
4. Create a cluster manually with element order Bool, Integer, String as already mentioned.
/Y
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 9 of 15
(4,628 Views)
Is this a version issue?
I downloaded the VI linked by the OP in order to check the version when I closed it - it was saved in 2012 LabVIEW. I feel like when I've seen older videos for LabVIEW tutorials, some of them had pink error clusters, however, googling didn't give me any information on when the current version error cluster as a separate type of cluster with a yellow wire was introduced.
LabVIEW 2012 help files seem to suggest that by 2012, error wires were already yellow (so that would throw a spanner in this wondering...) but nonetheless, I wondered if this could be the 'problem'.
GCentral
Message 10 of 15
(4,622 Views)
