Error List as txt file
I suppose you could use a case statement with a case for each of your error codes and use the error ring to generate a corresponding error code.  That's like what you want to do.  Use the error ring to select the error you want to generate.
Bill
CLD
(Mid-Level minion.)
Message 11 of 17
(1,172 Views)
The problem with that is that it is extremely difficult to cover all errors.  That's why I recommended the Create Error From Error Code and then use the General Error Handler to do the actual looking up of the error code for you.
Message 12 of 17
(1,164 Views)
I see.  I was thinking that he just needed a few error codes - but your solution is much more scalable.
Bill
CLD
(Mid-Level minion.)
Message 13 of 17
(1,147 Views)
Hey ph1,
i found something in our support portal, which might help you with your problem. I attach the document.
I hope that will help you with your problem.
Best regards
Dominik
Message 14 of 17
(1,118 Views)
Hi Dominik,
oh, those were the days! 😄
1997 edition of LabVIEW error codes. Wow! (I guess the changes are rather small in the last 17 years.)
Did I mention the LabVIEW help before? Something like the list of VISA error codes?
Message 15 of 17
(1,113 Views)
Hello Dominik,
I have found this document, too, some times ago but where "discourages" by it's age.
EPH
Message 16 of 17
(1,084 Views)
Hello GerdW,
after an intensive search in the help (I don't now, why it is so confusing) I was able to find the VISA-Error-codes there. This works fine. To my luck I only need the VISA-codes and not all the others...
EPH
Message 17 of 17
(1,080 Views)
