Error Code -229771
Hi ipc, did the -229771 error appear on a recent update of Microsoft Essential, or subsequent to the install of a particular NI product? Also, have you tried upgrading to DAQmx 9.4?
James M.
Applications Engineer
James M. | Applications Engineer | National Instruments
Message 11 of 18
(2,559 Views)
Hi James,
Yes, the error occured on the latest update of essential. I will upgrade it to DAQmx 9.4 and let you know.
Message 12 of 18
(2,557 Views)
I thought I should provide an update on my situation (the original post)...
It turned out that the switch from Norton 360 to Microsoft Security Essentials was only a temporary fix, resulting from the activity related to the change, not the change itself, if you know what I mean. Full credit to NI technical support for their persistence, the actual problem was determined to be this:
I had configured my computer (laptop) to be my primary connection to the internet, via wi-fi, because I was in a remote building, needing a wi-fi connection, and my desktop did not have a wireless capability.   Then, I shared this internet connectionwith my desktop. It was the internet connection sharing that was causing the problem, not the choice of security software.  NI would not reveal the exact nature of the problem, but indicated that possibly it had to do with the way Project Explorer uses TCP ports to transfer information with MAX. NI support submitted a fix request for future versions. NI recommendation was 'don't do that', i.e. share your internet connection like that.
Anyway, it turned out to be a very manageable problem, and it still recurs from time-to-time.  I am still sharing the internet connection, and I am still using Security Essentials.  When the problem re-appears, I turn off the firewall, then restart, check that the problem has gone away, then turn the firewall back on.  Occasionally I may have to repeat the procedure, but it always works.  I was given a port number, and un'blocked in my security software, but this also was not a permanent fix.
If the problem is particularly persistent, or if I am particularly impatient, then I simply work outside the Project Explorer for a bit.  Not recomended, I realize, but it is only for a short period of time, and I am usually just working on one or two VIs anyway.  I really only need Project Explorer to build executables.
So, the important point (in my case) is this.  It is Project Explorer that is causing the problem, not the security software, and it appears to be specifically related to the use of a port and how that interacts with internet connection sharing.
Hope this helps,
RonC
Message 13 of 18
(2,549 Views)
I completely removed National instrument software from (control panel)my computer and have now installed Labview 2011, with DAQmx 9.4. This has resolved my problem with getting the Labviwe freezing up.
Message 14 of 18
(2,530 Views)
This issue is not yet resolved. Even with a newer version of LabVIEW 11.0, the DAQmx freezes up LabVIEW and puts out Error code 229771. I also get this "transact.cpp", line 1425 error when I try to create a new DAQmx channel into a perfectly working code.
This issue has haunted me for a long time now. All versions 2009, 2010 and 2011 with all DAQmx versions have this issue. This has cost me number of hours of troubleshooting. Has anyone in the forum have dealt with this issue? Is NI doing something about this?
Message 15 of 18
(2,495 Views)
Hi ipc,
Have you tried all of the steps in this forum?
Similar to RonC, is this issue also only occuring when you're operating out of the Project Explorer window? Are you seeing any odd symptoms before running the VI and receiving the error? I'm assuming you've tried entirely disabling the antivirus software; are you running any other web services that may be conflicting with the Project Explorer?
Chris G
Message 16 of 18
(2,475 Views)
Hi RonC,
I was having similar problems where I was getting MIG errors on DAQmx channel create functions. I could not find a solution or work out what would cause the problem.
Recently on a trip overseas I set up internet connection sharing and forgot to turn it off. After reading your post and turning off ICS everything is back to normal no more error -229771.
Brett J
Message 17 of 18
(2,405 Views)
Glad I could help. You are welcome!
RonC
Message 18 of 18
(2,401 Views)
