Error 8 occurred at Read File+ (string): Read File
LabVIEW is giving an error of excel file not found. Then if I press continue the program runs fine and just goes to zero every few seconds.
Message 11 of 19
(2,414 Views)
Hi nsaeed,
All those problems because of missing error handling:
IF no error THEN
  do something with CSV data
ELSE
  try again
ENDIF
Message 12 of 19
(2,406 Views)
I am an amateur when it comes to lab view can you please elaborate as to how I can introduce error handling I tried using a case structure but am unable to find a way to detect when the error occurs to forward it to the case structure.
Message 13 of 19
(2,400 Views)
Hi nsaeed,
You really should take the training!
Use the error wire!
Message 14 of 19
(2,383 Views)
I tried that aswell, now I get no errors shown but still get the same errors.
Message 15 of 19
(2,373 Views)
Then could you share your csv file?  That is likely where your problem is.
Message 16 of 19
(2,362 Views)
Sure,
I have attached the csv file plus the latest version of my labview program.
In my csv in order to save the file every second I introduce a two vba's 1 in the thisworkbook object and the other in a general module.
I have attached these aswell.
Message 17 of 19
(2,360 Views)
Something's fishy here.  You're talking about a CSV file as if it were an Excel file.  It's not.  There's no such thing as a CSV "workbook".  I've opened up your "CSV" file and it is an Excel file with a CSV file extension.  I think you'll have to work this out before we can really help you.  It's likely that your failure to realize that a CSV file is a pure text file while an Excel spreadsheet is causing at least part of your issues.
Bill
CLD
(Mid-Level minion.)
Message 18 of 19
(2,293 Views)
Accepted by nsaeed
Sorry, but the format of your file is a mess.  It looks like you have a line for each variable, possibly multiple values.  But you throw in the variable names in the middle of the lines, with those strings being duplicated.  Those names will just be formatted into your 0s.  And then you have a bunch of "blank" values (multiple commas next to each other).  A simpler format would be to have the variable names first in the line and then the list of values for those variables.
And you could just use Read From Delimited Text File to do all of the reading for you.
Message 19 of 19
(2,289 Views)
