Error 7
Hi,I have a problem with path selection.The actual path it has to be select is \\coimachp.mach.corp\Data\EHS\multihub v2\17_ 9_2015.log.When i use the build path the appended path gives the same location as i mentioned above.but the read from measurement file gives the error as not a path.Can anyone help me to solve this?
Thank you in advance for your reply.
(4,499 Views)
Have you tried mapping \\coimachp.mach.corp\  to X:\ or something like that so that the path becomes X:\Data\EHS\multihub v2\17_ 9_2015.log
(4,447 Views)
(4,426 Views)
No i didn't try with that.Because the data is logging in that drive only as it is a common drive for everyone in the company i could't change that process to the unique PC's drive.
(4,397 Views)
Your answer just proves that you don't understand the concept of mapping a drive.  I suggest you Google it.
(4,363 Views)
