ā02-27-2006 05:59 PM
ā02-27-2006 06:16 PM
Most likely a bad path or the file exist and you can't overwrite it. Make sure path exist and make sure file that name it is trying to wirte is not there. The conversion may have changes a properity like overwrite to don't replace.
Hope this helps,
Matt
ā02-27-2006 07:50 PM
ā02-28-2006 08:02 AM
ā03-03-2006 05:03 PM
ā03-06-2006
07:36 PM
- last edited on
ā11-24-2025
09:06 AM
by
Content Cleaner
In addition to the LabVIEW Help, there is an Application Note on Distributing Applications with the LabVIEW Application Builder.
Also, here is a knowledge base article on what Dennis has described and it provides an example to call an extra Strip Path function. Also, instead of using a Match Pattern function, you could use the App.Kind property node (use Open Application Reference, Property Node: Application -> Kind, and Close Reference) to determine if you are running in a Run-time system.
Good luck and best regards,
Shakhina P.
Applications Engineer
