Error -41005
I have received this error from the Print report.vi: what does it means?
Where can I find some documentation on NI reports?
(3,532 Views)
If you have the manuals that came with labview, take a look in the appendix,
all the error codes are listed there. I don't have the manual with me at
the moment.
Cheers
John
Forfello wrote in message
news:87tuaa$fqs$1@pinco.nettuno.it...
(3,532 Views)
appendix,
>the moment.
This error code is not listed: it's an error generated by Print report.vi
and LabView 5.1 has no documentation for NIReports.
(3,532 Views)
If you roght click on the code portion of the error cluster and select "Explain
Warning", you'll see that, yes indeed it is generated by NI-Reports and the
reason is "Invalid margins"
"Forfello" wrote:
>>>If you have the manuals that came with labview, take a look in the>appendix,>>all
the error codes are listed there. I don't have the manual with me at>>the
moment.>>This error code is not listed: it's an error generated by Print
report.vi>and LabView 5.1 has no documentation for NIReports.>>>
(3,532 Views)
Check the small labview 5.1 Addendum booklet for NI reports documentation.
Its not great, but at least it something to refer to.
Cheers
John
John Cronin wrote in message
news:FNxo4.10575$VJ1.19639@newsfeeds.bigpond.com...
appendix,
> the moment.
> Cheers
> John
(3,532 Views)
Warning -41005 occurred at an unidentified location.
Possible reasons:
NI-Reports: Invalid margins
(3,532 Views)
