Error -30, when building new installer
LabVIEW 2010 sp1, just upgraded and lost the ability to build installer. Error dialog:
LabVIEW 2010 sp1
Win 7 64bit
Thanks in advance.
(3,878 Views)
Hi Cereal,
Can you give us a little more information on your issue? For example, which version of LabVIEW did you upgrade from? Did you modify any of your code? Are you having problems building ANY installers or just a single application?
Please include all other relevant information with your reply. This will help us better understand your situation.
Thanks.
Josh L.
(3,859 Views)
Original installed version: NI Developer Suite 2010 DS2
Code is unmodified
Application Builder Error occurs from any project.
Currently configured installers cannot be built either. When build configuration is viewed the additional installers section is empty.
I am currently working with an NI Applications Engineer to resolve the issue.
So far, article:
http://digital.ni.com/public.nsf/allkb/1B53A6FDFC20B8058625752400687F42?OpenDocument
has been suggested.
From my team of 6 the 3 that have upgraded have the same issue.
I will update the status once I try this fix.
Matthew E Crookshank
(3,854 Views)
This article mentioned did nothing to remedy the situation.
Will await more instructions for now
FYI. "Cereal" is my morning handle.
(3,848 Views)
Hi Altitude,
I'm in communication with Chris regarding this issue. We will try to resolve it off line for you.
btw, I don't know what "morning handle" means exactly, but it sounds funny. 🙂
Josh L.
(3,846 Views)
