el 07-21-2022 07:07 AM
Hi everyone,
can someone help me with this error? I want to generate this waveform with the formula in the string and always get the "Error -23083 occurred at an unidentified location"
"Possible reason(s): Analysis: (Hex 0xFFFFA5D5) Bracket problem at the end."
Thanks in advance.
el 07-21-2022 07:30 AM
You have an unbalanced set of "()"
el 07-21-2022 07:47 AM
But I use on each side 3 brackets. Where should it be unbalanced?
el 07-22-2022 10:35 AM
Considering that you covered the string constant, that would be at an unknown location.
