03-13-2006 02:42 PM
03-13-2006 02:55 PM
03-13-2006 03:06 PM
03-13-2006 03:34 PM
(Hey, what an exciting thread. Gotta love monologue
Ok, so I went through my channel list one at time and deleted each that was "corrupt". After each deletion, I quit MAX, restarted MAX, recreated the channel and moved on to the next. Now I can modify all the channels in my list, and create new ones. I'm lucky b/c my channel list was relatively small but this could have been quite bad if my list were a lot longer. NI, would be great if you could whip up some help file explaining what the error code means.
03-14-2006 06:38 PM
03-15-2006 07:12 AM
03-16-2006 07:17 PM
03-20-2006 08:24 AM
Hi there,
This is my first time on here and I've only been using this software for a couple of days so it's possible I'm making a trivial error but I thought I'd post here anyway as I can't find anything on the net about my problem.
I also get an error while trying to save:
Error -2147220733 occurred at DAQ Assistant
Possible Reason(s):
But mine comes about in different circumstances to the one in the original post on this thread by Kahless. I was editting a VI logger task and within that I was trying to edit an NI-DAQmx Task. I was trying to change the clock settings, specifically I was attempting to change the Rate (Hz) from the 1k default to just 20, or 200. I got the error while trying to save so changed it back to 1k, but the error persisted even though I'd set it back to what it was.
I thought at first it might be simply that I was trying to edit an NI-DAQmx task within VILogger, so I tried making the ammendment directly but the problem was still there.
Any ideas?
Many thanks.
03-20-2006 09:09 AM
Hey Anti-Neutrino,
I know my situation was somewhat different then yours but I think the underlying cause may be related. I too was experiencing this trouble when it came to saving my channel list. Maybe try giving this a whirl.
For me, there was no solution (as you can see) brought forth so I ended up deleting and recreating my channels. ( I didn't have too many of them). Not an elegant solution, but perhaps try doing this. It may help until NI comes up with a help document for the 2147220733 error. Note I found that creating new channels (or perhaps tasks in your case) would not function unless the program was closed and opened fresh. Once experience one 2147220733 error, I was not able to save anything (new or modified).
Hope this helps a bit.
03-20-2006 09:28 AM
