Error 20352
I am getting Error 20352, although my design is working but it gives this error message in error out dialog box. Can any body look at my design and guide me what is the problem?
(4,139 Views)
Accepted by josephkirmani
It's not an error - it's a warning. If it was an error the 'status' would be True (red).
If you click on 'Explain Error' from the context help, the description of the error is "Analysis:  Current and previous waveforms are not contiguous."
You're getting it because you're using an array of DBLs instead of a waveform so the function can't check that the end of the previous sample lines up with the start of the next one (a waveform has dt and t0 components).
(blog)
(4,133 Views)
