Error-201025 when using USB-6346
Because usb-6346 does not support'Hardware-Timed Single Point', so I tried to use '1chan1sample' to write single point data, but Error-201025 still occurs. How can I do for single point reading and writing at the same time without using 'Hardware-Timed Single Point'? thanks!
(2,844 Views)
Hi MaxPan,
don't use DAQmxTiming on your DAQmx task: you cannot define a sample rate (or continuous mode) when your hardware doesn't support hardware-timed operations!
Btw:
  • Don't use proprietary archive file formats like RAR. Use default ZIP as supported by any modern OS (like Windows). (On a mobile it's nearly impossible to handle such proprietary file formats!)
  • Don't use an archive just to attach two JPG images: attach/embed those images in your message! (No need to download an archive, uncompress that archive, view two images when you could embed those images within the message so anybody can view them instantly!)
(2,811 Views)
Thank you very much for your help, error-201025 has been resolved.
But something strange happened,there is no error will be generated under highlight execution,error will occur under without highlight execution,could you tell me how to resolve this proplem. thanks!
By the way, could you tell me why the graph won't display the output waveform. Thank you!
It's my first time use NI community and thanks your suggestion!
(2,805 Views)
Hi MaxPan,
I didn't got that error before: it might help to attach your VI as we cannot debug images with LabVIEW…
Are you sure the graph doesn't show the samples? As you programmed the VI it will show the data when the loop has finished - as dictated by THINK DATAFLOW!
On your VI:
Do you really need a formula node just to add an offset?
Do you really need to wire the very same array twice out of the loop?
Why does one 2D array indicator has lost its label?
Why do you still read the samplerate?
Mind to place a small wait inside the loop, like 1ms?
(2,800 Views)
Just guessing here:
Highlight execution is single threaded, won't let things run concurrently, that is why your application works. Connect an error wire between your two DAQ 1SAMP VIs in the For loop and I am guessing it will work, just maybe not the way you want it to work.
mcduff
(2,775 Views)
After confirmation, the same error will also occur when the loop has finished in highlight execution.
And i sure the wavefrom didn't show my output wave when the loop has finished. But the output array shows data, why?
1.Because my goal is to use formula node to do pid control operations, now I just do a simple example to test.
2. 3. i already corrected, thanks!
4.if i don't use'DAQmxTiming', how do I decide sampling rate? or just like my VI ('PID test')?
5.Because i worry about overwrite happens, it actually happens?
(2,766 Views)
Hi MaxPan,
Simplified VI:
Your VI didn't include any data in the frontpanel elements as requested, so I cannot comment on the different content of the chart and the 2D array…
1. Why do you need a formula node here? Use simple G nodes…
4. See the snippet: you just set a timing in the loop. (In your VI you set a sample rate of 10kS/s and try to read 1 sample per loop iteration: your loop will NEVER run fast enough to keep up with that sample rate!)
5. I don't know what you are referring to…
(2,751 Views)
