Error-200284 with DAQmx
I am trying to make a continuous reading of analogvoltage signal with DAQPad-6015/6016 using sampling rate of 1000 and number of sample=1000 but the DAQmx is showing
Error-200284 saying that the some or all samples requested have not yet been acquired.
The vi is attached and the images showing the settings of the DAQmx,error mesaage are also attached.
Can I know to solve this error.
Thanks.
Message 1 of 10
(5,348 Views)
Switch from Finite Samples to Continuous. Deleting the Start Task function also seems to work.
Message 2 of 10
(5,334 Views)
If you delete the Start Task, the read auto-starts the task on each loop iteration.  This would introduce a noticeable delay between each grouping of 1000 samples.  You probably just want to switch to a continuous acquisition.
Best Regards,
John Passiak
Message 3 of 10
(5,314 Views)
Thanks.
And when I tried to implement the below
1)DAQ should acquire the samples for a 1sec and filter the signal
2)After done with the 1 sec duration of signal acquiring it should go into while loop for the continuous acquiring of signal in which after every 1 sec it should show the signal on the waveform(frontpanell)
I got these problems
1) error as shown in the attached image 2)the timeout ,blocksizes and waveform are shown twice on the frontpanel
Can you suggest how to make a better implementation. I also attached vi .
Message 4 of 10
(5,282 Views)
Go back to the program that you linked in your first post and change the sample timing type to Continuous.  Don't make any of the other changes you have incorporated (the sequence structure and the wait).
You can add the filtering inside the while loop.  I guess you only want to filter the first set of data and show this statically on the front panel while you continue to acquire and display unfiltered data? You could put the filter VI and the filtered indicator inside a case structure and use the First Call? primitive.
Best Regards,
John Passiak
Message 5 of 10
(5,256 Views)
Message 6 of 10
(5,245 Views)
Accepted by topic author GoviRe
That clarifies a bit, it shouldn't be complicated.  Something like this?
Best Regards,
John Passiak
Message 7 of 10
(5,237 Views)
thanksalot,
And If possible can I get some clarification like after the 2nd iteration two outputs are generated from the 2nd adaptive block and in this the e(n) is supposed to be fedback as input to the same adaptive filter  and this feedback of  previous otuput as one of the current input should be done for each iteration .can I know how this works with your posted image(vi).
Message 8 of 10
(5,228 Views)
can someone explain a bit about the above question.
Message 9 of 10
(5,194 Views)
The resulting e(n) is used as the d(n) input of the next iteration due to the shift register.
Best Regards,
John Passiak
Message 10 of 10
(5,105 Views)
