Error -200220: Device identifier is invalid
We are trying to run a simple program we wrote in LabVIEW 8.5 using a DAQ board for my research experience class and are having some issues. We are running it on a Mac OS X. We are getting an error message that reads "Error - 200220: Device identifier is invalid.
Here is a picture of the program we are trying to run:
(5,005 Views)
Check if you have provided valid DAQ resource name in the "Physical channels" control.  The DAQ card installed in the system must be selected in the physical channels control so that the vi functions as expected.
Post back if any queries.
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(4,987 Views)
To use the DAQmx Create Virtual Channel.vi, your chassis needs to be verified under NI-DAQmx Devices.  Once you have confirmed that the chassis is present and configured under NI-DAQmx, the physical channels input should self-populate with a list of available channels. Check the filtering of the names if the physical channel string you are using does not show up, you can do this by right clicking on the physical channels control and editing its properties.
I hope this extra bit of info helps!
John McLaughlin
Academic Account Manager
National Instruments UK & Ireland
(4,983 Views)
