Error -1950678961 from Read Variable.vi
Hello Forum
has anyone ever encountered this error? the error code is undocumented.
CY (expired CLAD)
(3,027 Views)
Accepted by topic author cy...
Hi cy,
That error number is documented:
(3,012 Views)
many thanks GerdW. I searched only from the ni.com, my bad.
any idea on alternative reasons that can trigger this code when I have no close variable connection functions nearby? state machine architecture, close variable connection outside of state machine
CY (expired CLAD)
(3,005 Views)
Be careful in how you search.  If you search with the negative sign in front, then the search engine interprets the negative sign that you want to find things that DO NOT include that value. The exact opposite of what you want.  So when searching, always make the error value positive.
(2,995 Views)
