Error 1722.
What is the latest run-time engine version you have installed.  I've seen this error before but I believe it was specific to having the 7.1.1 RTE installed and causing problems.
Alex Person
NI-RIO Product Support Engineer
Message 11 of 16
(2,466 Views)
It is 7.1.1. I tried to repair RT 7.1.1, it doesn't help. And then I repair Laview 7.1, still not work. Yestorday, I need to uninstall all of NI product from my PC and re-install labview 7.1----finally the problem solved.
But this kind of problem already happened in my PC twice. It is killing me. I am looking for a solution how to prevent and solve the problems easily.
Message 12 of 16
(2,458 Views)
Nobody can help?
Message 13 of 16
(2,438 Views)
lvfanqie,
I noticed that you stated that this has happened on the same computer.  You may want to try running a Chkdsk on your computer.
I was having similar problems with a computer that had a bad sector, and was causing me to have to reinstall LabVIEW.
-SS
Message 14 of 16
(2,431 Views)
I've been having the same problem, trying to run a Laview 7.1 installer.  I get the following message in my event log...
Event Type: Error
Event Source: MsiInstaller
Event Category: None
Event ID: 11722
Date:  11/11/2009
Time:  16:01:06
Computer: DEREKR01
Description:
The description for Event ID ( 11722 ) in Source ( MsiInstaller ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: Product: TestSoftware -- Error 1722. There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor.  Action Action4.36417545_AD4C_11D7_8406_00C0F03EBEBE, location: C:\Program Files\National Instruments\Shared\USI\Bin\, command: "C:\Program Files\National Instruments\Shared\USI\Bin\usireg.exe" /i /u "C:\Program Files\National Instruments\Shared\USI\Bin\uspLVM.uri" , (NULL), (NULL), (NULL), (NULL), , .
Data:
0000: 7b 30 35 43 42 41 31 35   {05CBA15
0008: 38 2d 33 46 44 45 2d 34   8-3FDE-4
0010: 30 46 38 2d 38 32 35 42   0F8-825B
0018: 2d 44 46 44 45 35 37 31   -DFDE571
0020: 41 33 32 38 38 7d         A3288}
I've tried a scan disk, and that didn't help. Next move is to remove Labview completely from my PC and do a fresh install.  Is there anything else I can try before I start again?
Best wishes
Derek
Message 15 of 16
(2,343 Views)
You can the latest version install on your computer.update and solve the error 1722 and you can help for recovery fix.
Message 16 of 16
(2,102 Views)
