Error 1722.
I tried to uninstall an executable that was written in Labview 7.1 and I get an error message saying. "Error 1722. There is a problem with the windows installer package.  A program run as part of the setup did not finish as expected..."  How do I uninstall this executable.  Any help is greatly appreciated.
Message 1 of 16
(9,895 Views)
Error 1722 is all over the forums, search the forums for "Error 1722".  -SS
Message 2 of 16
(9,893 Views)
All of the posts that I found in the forums deal with run time engine or Labview itself.  I haven't found anything that deals specifically with an executable that was written with Labview.
Message 3 of 16
(9,883 Views)
Hey Cstash,
Can you tell us how have you been uninstalling the executable in detail?
Are you trying to uninstall LabVIEW components as well?
The reason why I am asking is because the error code relates to Error 1722 or 1721 When Uninstalling LabVIEW 7.1.
Message Edited by Aashish_M on 08-14-2008 02:08 AM
Aashish M
CEO
TransferFi
www.transferfi.com
Message 4 of 16
(9,853 Views)
****Same hyperlink mentioned above****
****Message deleted****
Message Edited by muks on 08-14-2008 02:55 AM
Message 5 of 16
(9,849 Views)
I try to uninstall it in the control panel and by reinstalling the executable.  Either way it starts the process and then it gives me error 1722.
Message 6 of 16
(9,835 Views)
HI,
I got the similar problem when I try to install/uninstall an execulable app from my computer. I can't find the related resolution in this forum.
Can anyone helps?
Thanks!
Message 7 of 16
(9,494 Views)
BTW, this the log file I saved when I run installation.
=== Logging started: 7/20/2009  12:38:33 ===
Error 1721. There is a problem with this Windows Installer package. A program required for this install to complete could not be run. Contact your support personnel or package vendor. Action: Action4.36417545_AD4C_11D7_8406_00C0F03EBEBE, location: C:\Program Files\National Instruments\Shared\USI\Bin\, command: "C:\Program Files\National Instruments\Shared\USI\Bin\usireg.exe" /i /u "C:\Program Files\National Instruments\Shared\USI\Bin\uspLVM.uri"
Message 8 of 16
(9,488 Views)
Did you see the link mentioned above? What is your lv version?
Message 9 of 16
(9,467 Views)
Hi Muks,
I am using Labview 7.1. The link above is about error when uninstall labview. It's not the same case I have here.
I tried to uninstall an execuable application built by Labview.
Message 10 of 16
(9,457 Views)
