01-29-2021 05:20 PM - edited 01-29-2021 05:45 PM
I'm trying to copy a file via ftp. I'm running the vi from a Windows system, trying to get the file from a system running on Windows CE. I can get and copy the file just fine using Windows Explorer. But when I try do do it with LabView, I get a Syntax Error message. Can anyone help my see what's wrong in my vi? Thanks a lot.
02-18-2021 06:23 PM - edited 02-18-2021 06:24 PM
Still haven't figured out this one. Filezilla can access the FTP server no problem, but LabVIEW keeps refusing. Any ideas anyone?
07-07-2022 07:51 PM
I am having the same problem communicating to an FTP server on an Allen-Bradley Panelview. Did you ever figure out what was causing the issue?
07-08-2022 02:38 AM
Are you sure it is the same problem? The previous poster obviously did not successfully login (as indicated by the error message returned by the second function, although it is not translated into an error cluster error, it very clearly states that there was a syntax problem in the command).
Generally an empty username and password is not considered as valid login credentials, but instead FTP defines "anonymous" as the canonical user with minimal rights. And please note that FTP servers can and actually should be configured to disable anonymous nowadays as it is a highly critical security risk (as the entire FTP protocol really is).
07-11-2022 07:05 AM
My apologies, similar problem. Yes I am aware of FTP's security issues. Thanks for your feedback.
