取消
显示结果
搜索替代
您的意思是:
Error 1502 occurred
Hi All,
Error 1502 occurred at AB_Source_VI.lvclass:Close_Reference.vi -> AB_Build.lvclass:Save.vi -> AB_Build.lvclass:Copy_Files.vi -> AB_Application.lvclass:Copy_Files.vi -> AB_EXE.lvclass:Copy_Files.vi -> AB_Build.lvclass:Build.vi -> AB_Application.lvclass:Build.vi -> AB_EXE.lvclass:Build.vi -> AB_Engine_Build.vi -> AB_Build_Invoke.vi -> AB_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW:  Cannot save a bad VI without its block diagram.
This error i am getting when i am trying to builg the EXE.
Help me.
Thanks and Regards,
Rams
0 项奖励
1 条消息(共 7 条)
5,355 次查看
Hi Rams ,
Can you please upload a snapshot of the error. so that I can better understand
0 项奖励
2 条消息(共 7 条)
5,342 次查看
0 项奖励
3 条消息(共 7 条)
5,340 次查看
I had the same error in a VI that used to compile without any problems. But after changing this VI's code error 1502 error popped up. I tried some of the suggestions in the thread you proposed except enabling debugging but it did not help. The changes I made to the code included a case structure with a Boolean constant wired to the selector input. By doing this one of the cases would never execute and this was my way to save some old unused code code for the moment in the TRUE-case and putting some new code in the FALSE-case. Apparently the LabView compiler does not like this because removing the case structure and leaving only the new code made the compiler build my application without errors.
0 项奖励
4 条消息(共 7 条)
5,282 次查看
Also see here:
http://forums.ni.com/t5/LabVIEW/bleep-you-error-1502-shakes-fist/m-p/2252430
Certified LabVIEW Architect
TestScript: Free Python/LabVIEW Connector
One global to rule them all,
One double-click to find them,
One interface to bring them all
and in the panel bind them.
0 项奖励
5 条消息(共 7 条)
4,735 次查看
You forgot to see the date 吐舌表情
0 项奖励
6 条消息(共 7 条)
4,731 次查看
No the 2012 compiler does not like dead code.  use a disable structure to disable code
"Should be" isn't "Is" -Jay
0 项奖励
7 条消息(共 7 条)
4,728 次查看
