Error 1502 Excel Add Reference to VBProj.vi
This seems like a Microsoft vs LabVIEW compatibility error.  Trying to build an application I receive "Error 1502 occurred at AB_Source_VI.lvclass: Close_Reference.vi->AB_Build.lvclass: Save.vi".  The broken vi is located: C:\Program Files (x86)\National Instruments\LabVIEW 2016\vi.lib\addons\_office\excel.llb\Excel Add Reference to VBproj.vi.  I hesitate to send out another service request as I do not wish to re-install LabVIEW or "make the program again".  The second image is the same as the first except the tip strip is visible in the second.  I am unable to right click and "relink" in the same manner that worked the last time there was an ActiveX change/issue/thing.  I await some condescending responses and hopefully a good suggestion.  Thanks.
(6,474 Views)
Accepted by hefengloven
A colleague was able to perform an application build with the source code on his machine.  I replaced the _office folder with a copy of his and I am now able to compile again.
(6,425 Views)
I encountered the problem again.  The application builder broke the vbproj.vi.  I opened my control panel and performed the quick repair on Office 365.  It took about 30 seconds to repair.  When I opened the vi again it was miraculously fixed.  I guess an office file went missing, no idea why, I feel LabVIEW is responsible.  I am now able to build the application again.
(6,372 Views)
"I opened my control panel and performed the quick repair on Office 365."
Could someone precise how to do this, please? I also have the same problem after installing Office 2016 (365).
Thanks!
(6,149 Views)
Lasting Fix:
1.  Open the NI_ReportGenerationToolkit.lvlib:Excel_Save_Workbook.vi
2.  LabVIEW then recompiles the VI for whatever version of LabVIEW is being used.  So when we try to exit the VI we get this:
3.  It is at this stage that we get the broken arrow:
4.  At this point we can right click on the invoke node and relink it to the active X library it's calling which results in an extra field:
5.  After this the VI works without issue.
If we fail to relink the invoke node, the VI will save in a broken state and become unusable until someone relinks the invoke node.
NI has been sent the fix.
Good Luck!
(6,141 Views)
Thanks hefengloven,
I made the correction, but stiil have the same problem you had on 04-24-2017 post, where _Workbook>VBProject output was a Variant instead of an Automation reference of class in NI_Excel.lvclass:Excel Add Reference to VBProj.vi.
Would I be missing something?
(6,133 Views)
Hi DCanQAlias,
did you manage to solve the problem? I have the same problem of having outputs as Variant instead of Reference.
I've reinstalled LabVIEW and Office and even Windows, which corrected it but after a day, the problem appeared again.
Any help will be much appreciated! Thanks!
(2,337 Views)
