01-25-2010 02:42 PM
I receive the following error when trying to build an applications Build Specifications:
Error 1430 occurred at Create Folder in Create Directory Recursive.vi->AB_Destination.lvclass:Create_Destination.vi->AB_Build.lvclass:Create_Destinations.vi->AB_Application.lvclass:Create_Destinations.vi->AB_Build.lvclass:Build.vi->AB_Application.lvclass:Build.vi->AB_EXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW: The path is empty or relative. You must use an absolute path.
<Not A Path>
Any Ideas?
01-26-2010 12:35 PM
This was reported to R&D (# 156236) for further investigation. It is generally a result of including a subVI that is stored on a network drive. If you are building an executable, you can try checking the Use LabVIEW 8.x file layout option under the Advanced category. If you are building a source distribution, make sure the Preserve disk hierarchy option is not checked under the Destinations category.
Let me know if any of this information resolves the issue.
01-26-2010 12:58 PM
02-03-2010 03:51 PM
Using the 8.x layout worked for me.
Doesn't seem to have created the support directory with dll's though. (may be separate issue, will investigate)
