Error 1172 when generating .NET interop assembly for array output with class type
we got an error when generating a simplistic toy .NET interop assembly if the source VI returns an array with non-standard LabVIEW (class) type. If the returned value is not an array, it works with any type.
I attached the LV project (version 2014 no SP).
Any idea?
Peter
(3,943 Views)
Accepted by topic author bokorpet
FYI: NI has confirmed it to be bug and issued a ticket CAR 606191.
The recommended workaround is as follows:
"Regarding a workaround, if they really need to build an array of classes, one
suggestion was to access the data inside the class as a cluster, and to build
an array of clusters instead of an array of classes. He could then build that
into a .NET interop, and once he sends that over to his text-based program (I'm
assuming this is what is happening?), he can build it back into a class.
If for whatever reason he is sending it to another LabVIEW instance, he can
also flatten the class into a string."
(3,753 Views)
