Error -1074396120 occurred at IMAQ FFT
Hi. I'm new here. I have attached a VI file here that has an error once I try to filter my loaded image. The error occurs on IMAQ FFT and it says, it requires an image. Can you please help? Thanks.
Message 1 of 10
(5,623 Views)
Is this same account?
http://forums.ni.com/t5/LabVIEW/Error-1074395397-occurred-at-IMAQ-InverseFFT/m-p/3353962
-If it is same, you don't have to create duplicate account and duplicate posts.
-If not then same solution applies to your case too.
uday
Message 2 of 10
(5,618 Views)
It is not the same, I do not have any idea about what that person is doing. Thanks
Message 3 of 10
(5,609 Views)
I tried to do that shift register, and it's not working yet. I'll keep you informed when I finished fixing this. Thanks
Message 4 of 10
(5,601 Views)
post your updated code, it is easier to debug then going with assumptions with what you did.
uday
Message 5 of 10
(5,597 Views)
Error -1074396154 occurred at IMAQ InverseFFT
That is the follow up error, I encounterd. The shift registers doesn't fix the problem yet
Message 6 of 10
(5,595 Views)
Message 7 of 10
(5,590 Views)
Message 8 of 10
(5,581 Views)
I can't open the file because I'm using LabVIEW 2013. Sorry and thanks a lot.
Message 9 of 10
(5,576 Views)
Accepted by GlennyGoosey
Message 10 of 10
(5,573 Views)
