Error -1074395989 occurred at IMAQ ReadFile
Hey!!  i'm getting Error -1074395995 occurred at IMAQ ReadFile.
I don't know why it happens. could someone please help me. Here is a picture of my Code:
Message 1 of 11
(8,450 Views)
Hi moidrissou,
why do you use quotation marks in your file path constant?
And what kind of path do you expect when adding a full path including "C:\" to your AppDir path?
Message 2 of 11
(8,441 Views)
Hi GerdW,
i first want to thank you for your reply. sorry for the quotation marks, it was a mistake. i changed it but i still have the same error. can you please tell me if the path i generated is ok. i want to Read an image, which i saved in this path. the picture is saved with the name lion. Unbenannt.PNG
Message 3 of 11
(8,437 Views)
Accepted by topic author moidrissou
Hi moidrissou,
Well, you still try to add a full path to your AppDir!
Why don't you get rid of that BuildPath function? The path to your image is defined just from your file constant!
No I can't: you only added an image instead of your VI. It's hard to debug images with LabVIEW…
Why don't you put a probe/indicator after BuildPath to check that path on your own?
Message 4 of 11
(8,431 Views)
here is my code
Message 5 of 11
(8,422 Views)
Message 6 of 11
(8,412 Views)
Hey, I am facing a similar problem in my program. Could you tell me how you got rid of the error?
Would be really helpful.
Message 7 of 11
(7,612 Views)
He followed the instructions given in several messages of getting rid of the Build Path where he was combining a full path with a full path.
How similar is your problem actually?  Attach your code and we can actually tell.
Message 8 of 11
(7,602 Views)
I am trying to load the face recognition program on a myRIO. But everytime I run the program, I get an error saying IMAQ vision : File not found.
Could you help me out with this problem and let me know how to upload this on myRIO.
The program works perfectly when i run it independently on LabVIEW. Uploading it to myRIO shows me an error.
Message 9 of 11
(7,597 Views)
