06-26-2017 06:27 AM
Hey!! i'm getting Error -1074395995 occurred at IMAQ ReadFile.
I don't know why it happens. could someone please help me. Here is a picture of my Code:
06-26-2017 06:40 AM - edited 06-26-2017 06:41 AM
06-26-2017 06:52 AM
Hi GerdW,
i first want to thank you for your reply. sorry for the quotation marks, it was a mistake. i changed it but i still have the same error. can you please tell me if the path i generated is ok. i want to Read an image, which i saved in this path. the picture is saved with the name lion.
06-26-2017 06:54 AM
Hi moidrissou,
Well, you still try to add a full path to your AppDir!
Why don't you get rid of that BuildPath function? The path to your image is defined just from your file constant!
No I can't: you only added an image instead of your VI. It's hard to debug images with LabVIEW…
Why don't you put a probe/indicator after BuildPath to check that path on your own?
06-26-2017 07:00 AM
here is my code
06-26-2017 07:09 AM
it works. thank you verry much 🙂
06-10-2018 12:55 PM
Hey, I am facing a similar problem in my program. Could you tell me how you got rid of the error?
Would be really helpful.
06-10-2018 02:07 PM
He followed the instructions given in several messages of getting rid of the Build Path where he was combining a full path with a full path.
How similar is your problem actually? Attach your code and we can actually tell.
06-10-2018 02:28 PM - edited 06-10-2018 02:29 PM
I am trying to load the face recognition program on a myRIO. But everytime I run the program, I get an error saying IMAQ vision : File not found.
Could you help me out with this problem and let me know how to upload this on myRIO.
The program works perfectly when i run it independently on LabVIEW. Uploading it to myRIO shows me an error.
06-10-2018 02:56 PM
Moved to new thread here.
