Error 1074388985 at every Frame API CAN Examples
hi, i work with the NI USB-8473 high speed can box, and LabView Version 8.2 when i try out any NI CAN FrameAPI examples (CAN Transmit - event based.vi, CAN Receive.vi,..); the Error Message "1074388985" already appears at the ncConfigCANNET.vi the installation & configuration should be ok. Any Idea? Thanks, Ralf
(4,071 Views)
Deat M. Lang,
I search about the problem that you posted.
On our web site, I found some informations and some helps about that:
The first thing is a page which explain the supported function of your device:
http://digital.ni.com/public.nsf/allkb/E1A44077DA6C819186257288006B76D7?OpenDocument
The next one is a Forum with some explanations about how to use the function:
http://forums.ni.com/ni/board/message?board.id=170&message.id=278249&requireLogin=False
Can you please send me more informations about the program, the driver and the versions that you use?
Have a nice day.
Matthieu
(4,058 Views)
hi Matthieu,
thx for your reply.
i've found yesterday morning one cause for the error-message (after software re-install);
-> it's not possible to start the ni can bus monitor & afterwards using any can.vi application.
is that a normal thing?
greets Ralf
Additional Information:
Windows XP SP2
LabView Version 8.2.1 (German)
Measurement & Automation Explorer 4.2.1.3001
NicanErr.txt:
[DRIVER_VERSION_SECTION]
NICAN.DLL_VERSION=2.5.0f0
NICANFRM.DLL_VERSION=2.5.0f0
DRIVERS\NICANPK.DLL_VERSION=2.5.0f0
NICANPU.DLL_VERSION=2.5.0f0
NICANTSK.DLL_VERSION=2.5.0f0
NICANCFQ.DLL_VERSION=2.5.0f0
NCVI.DLL_VERSION=2.5.0.12288
NICAN_S1.NFW_VERSION=2050000
NICAN_S2.NFW_VERSION=2050000
NIDNT_S1.NFW_VERSION=1050000
Message Edited by LangR on 01-12-2008 09:30 AM
(4,046 Views)
Message Edited by LangR on 01-12-2008 09:31 AM
(4,044 Views)
did you read the links that I posted?
I think that you did not close the reference on the CAN or something else.
Let me know.
Matthieu
(4,027 Views)
hello,
yes, i've read the posted links (supported functions & Error code 0xBFF62007 using ncConfigCANNet.vi)
but i didn't have another open reference or something else;
the only open application was the "can bus monitor" from the measurement & automation explorer.
greets Ralf
(4,011 Views)
Hi Ralf,
did you already tried to make a repair of your software?
It can help...
Have a nice day.
Matthieu
(4,004 Views)
