Error -1074118653 occurred at niRFSA Initialize.vi
I am currently using NI PXI-1045 to test RF signal from a device under test. I am using an exact copy of an example used for NI-RFSA. The unit under test is connected to the input of Ni PXI-5600 which is wired with Ni PXI-5142 to create NI-PXI-5661. When I run my vi, I got the following message " Error -1074118653 occurred at niRFSA Initialize.vi
Possible reason(s):
The device specified is not supported by this driver.
Status Code:-223543"
Would you please help?
Jean-Richard
JR
(4,576 Views)
Is your 5600 device in slot 2 of your PXI chassis as that is what the default control is showing.
Now Using LabVIEW 2019SP1 and TestStand 2019
(4,570 Views)
My 5600 device occupies slots 8 thru 10. By the way, I am using Labview 8.6.
JR
(4,564 Views)
OK so to get this to work on your front panel click on the down arrow of the 'Resource Name' control and select 'refresh'. Now it should show the correct PXI # and Slot #.
(4,561 Views)
It now indicates PXI slot 8. After running it, I received another error message: Error -1074118649 and the possible reason is that the digitizer resource name is not specified. It needs to be specified in MAX.
JR
(4,554 Views)
Accepted by Jean-Richard
OK, then open Measurement and Automation Explorer(MAX). It sounds like you need to associate the downconverter with the digitizer. On the left side of MAX expand the devices and interfaces tree and then expand the chassis tree. Right click on the 5600 device (slot 😎 and select properties and associate it with your digitizer.
(4,551 Views)
It works! Thanks for all your help.
JR
(4,503 Views)
