Error -1073807343 occurred at niFgen Initialize.vi
I'm having issues the issue as above.
I have a PXIe Chasis. I've swapped the controller to a brand new one. (Same model - PXIe 8133). Just the controller has been swapped nothing else.
I wanted to set up a new one and only use the LV Runtime and the exe file created with LV Runtime 2009.
On the new controller I keep getting this error when I run my application.
Everything works great on the old one but the old one has the Full LV Development system installed on it
The new controller that I get the error on:
It has preinstalled LV runtime so I did not install it.
I've installed the NI Device drivers first from the 2010 DS2 Device Drivers disk. But I got the error when I tried to run the app.
I uninstalled the drivers and insalled older ones from 2010 DS1 ( as I thought this could help as those are the drivers for LV 2009 SP1 which was used to create the exe file )
I get the same problem however.
The exe file works it has been tested on many devices but they all had the full development system installed on them.
Any hints?
(2,660 Views)
Accepted by topic author Mac671
Just wanted to post on this topic.
I got the issue resolved, thanks to an NI Support person.
It was related with one of my NI Cards I got installed.
For some reason on the NEW Controller in the MAX I could se 2 instances of the card.
One active , one not active.
I've plugged in the old Controller and exported it's MAX configuration to a file.
I've plugged back the new controller and opened MAX:
1) I've removed ( deleted ) the inactive NI Card From the list in MAX
2) I've imported the configuration form the pervious contoller.
It started working.
(2,634 Views)
