Error - 1073807302 with Agilent GPIB
Hi forum,
I want to use an Agilent gpib - USB cable to communicate with a network analyzer.
Agilent IO libraries had to be installed and the tulip passport has been enabled. The device is visible on NI Max and responds normally to GPIB queries (see ni_max.png)
Unfortunately though, the device is not picked up by labview, running this very simple program, an error is generated:
Error -1073807302 occurred at VISA Find Resource in visa_test.vi
Possible reason(s):
VISA: (Hex 0xBFFF003A) Unable to start operation because setup is invalid (due to attributes being set to an inconsistent state).
Interestingly, if the GPIB device is removed, the program functions well and displays a com port, provided that labview is restarted after removing the device.
Thank you in advance,
sgt peppers
(4,720 Views)
there is a KB that deals with this error. Please have a look at this.
VISA Error -1073807360 (system error) or Error -1073807302 when Stop Bits Set to 1.5
http://digital.ni.com/public.nsf/allkb/D2084EC381319CC386256A1D006F1415?OpenDocument
Regards
(4,667 Views)
Regards
The KB indicates the problem is caused by having an OS mismatch of databits and stop bits I have 8 data bits and 1 stop bit which shouldnt be an issue according to the KB.  Are there any other issues that can cause this error message?  I am getting the error message when I request the status bit via VISA STB.
-Regards
eximo
_______________________________________________
UofL Bioengineering M.S.
Neuronetrix
"I had rather be right than be president" -Henry Clay
(4,325 Views)
Hi, I am having the same problem. I followed the instructions here: http://literature.cdn.keysight.com/litweb/pdf/5990-3731EN.pdf. \
Done doing these:
– Enable the NIVISATulip.dll, and
– Enable the Keysight IO libraries Suite to work with NI 488.2.
Yet, my VISA Interactive Control shows "VISA: (Hex 0xBFFF003A) Unable to start operation because setup is invalid (due to attributes being set to an inconsistent state)".
Any help is greatly appreciated. Thank you very much!
(3,337 Views)
it is old thread although it is useful for other
Here is the link may be useful in your case. For me, Worked super.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kHMpSAM&l=de-DE
Kuddo welcomed
CLAD-CTD
(3,182 Views)
You probably just need to enable the Tulip Driver in NI-Max
=== Engineer Ambiguously ===
(3,162 Views)
