‎07-29-2009 05:41 AM
What does the Error -1073807253(framing error) indicate?I basically was trying to send data through the serial port via hardware ie a 2051microcontroller+MAX232 IC to the COM port and when i checked it in RS232Analyser i had no problem i could transmit data from my uC and recieved it in the RS232 window. But now when i connect it to the labview program as shown in the screenshot it gives an error
‎07-29-2009
05:53 AM
- last edited on
‎01-11-2026
04:04 PM
by
Content Cleaner
Hi Guest of NI,
Check this for more info about it. And search it in the KnowledgeBase.
‎07-29-2009 06:52 AM
thx THN but i already mentioned in my post dat it is a framing error...i did run a search for it in the knowledge base as well but couldnt find it...
‎07-29-2009 09:26 AM - edited ‎07-29-2009 09:26 AM
You should be discussing this in your original thread so people know what's going on and don't have to spend the time providing the same answers that have already been given.
guest of ni wrote:thx THN but i already mentioned in my post dat it is a framing error...i did run a search for it in the knowledge base as well but couldnt find it...
Then you need to look a little harder. There are tons of hits in the forums and on the NI site regarding a framing error.
